What am I over looking?
Old Apr 10, 2011 | 07:21 PM
qws's Avatar
qws
Default What am I over looking?
Code 23- IAT LO
Sensor tests out fine- ohm'd out cold and hot
key on ... 5 volts at sensor
Both wire leads from ECM test good to the connector
Old Apr 10, 2011 | 09:47 PM
C409's Avatar
C409
Originally Posted by qws
Code 23- IAT LO
At this point , I would try a new sensor ... they're only around $10 ... I get that code whenever I forget to plug it back in ... mine is in the air filter housing
Old Apr 10, 2011 | 10:45 PM
qws's Avatar
qws
I've gone threw 3 of them since last summer. It will be fine then shows up again. Location on a HSR is bottem center of the plenum. I'm thinking about changing the style of sensor I use to one that has the holes in the sensor end.
Old Apr 12, 2011 | 09:06 AM
C409's Avatar
C409
It could be an intermittent contact problem anywhere along the wiring path ... did you have to extend the wiring to fit the HSR ? ... Check the connector behind the distributor by the firewall ... its in a spot that would be prone to contamination , near the oil sender ...
To What am I over looking?
