power steering (?) fluid leak
Old Apr 10, 2011 | 07:22 PM
Crepitus's Avatar
Crepitus
Default power steering (?) fluid leak
I need some ideas to help figure out a fluid leak. After a 140 mile highway drive there is a ounce or two of fluid on the inside of the hood, right over the power steering reservoir. Not a lot on the front of the engine. The level is about 1/4" above the low mark when cold. I have made this run several times in the last few weeks with out a prob. any ideas? Is there supposed to be a gasket under the ps cap?
Old Apr 10, 2011 | 07:31 PM
leesvet's Avatar
leesvet
There is an O-ring that likes to fall off when the cap is removed and lifted away.
There is also a vent hole in the cap. When the pump starts to fail, cavitating and causing the oil to foam it will blow out of the vent hole in the cap.
Old Apr 10, 2011 | 10:59 PM
Crepitus's Avatar
Crepitus
Thanks Lee
Old Apr 10, 2011 | 11:11 PM
leesvet's Avatar
leesvet
when it does foam and fill the resevoir to overflow with bubbles...shut it off, and sit still for 5 min and it will settle down. Then you can drive it and all will be normal once its warm and the bubbles have gone.
Get some LUCA PS rack conditioner and add half the bottle. That will buy some time....maybe pickup a O-ring too.
Old Apr 11, 2011 | 11:45 PM
Crepitus's Avatar
Crepitus
That sounds like a good idea. If I can get it to hold on for a while it would help a lot. Ill pick up some Lucas tomorrow.
Old Apr 12, 2011 | 04:19 AM
86PACER's Avatar
86PACER
The best method is with UV leak dye. They make dyes for coolant or oils. Simply pour it into the suspect fluid (in this case the steering fluid). Then later you put on a pair of yellow glasses from the kit and go looking for the leak with a UV light. The leak will glow under the UV light.
This method is highly accurate. Your can purchase these kits at some local parts stores along with the dye. They aren't that expensive. I've seem some for under $20 and the dye runs about $8 for a 1 oz pour which is all you need. It takes all the guesswork out of it. No guessing or trying to wipe everything down to see where the leak is.
Old Apr 12, 2011 | 06:56 AM
RichS's Avatar
RichS
Are you sure its PS fluid? Usually when the waterpump starts to leak out the weephole, it drips on the belt slinging it on the hood. Most of the ps leaks I've seen were at the high pressure fitting on the pump. The line gets a hairline crack at the fitting.
To power steering (?) fluid leak
