Porting question, what if......
Old Apr 17, 2002 | 06:53 PM
1CanuckVette's Avatar
1CanuckVette
Default Porting question, what if......
What if you smooth out your intake runners too much, and intake ports.
Asking because I just spoke to the machinist and he warned me about having the intake side too smooth. Should I be worried about this or is it just another opinion. I know carb intakes need it more but with good injectors would there be a problem with fuel puddling. Help gonna loose sleep over this, need some advise on what you've seen and heard. :eek:
:cheers:
Old Apr 17, 2002 | 06:56 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Porting question, what if...... (1CanuckVette)
Our injectors spray the fuel onto the back of valves so I don't think puddling is any issue, even in the head runners; certainy no in the base runners or above.
I"ll bet he's a carb guy not an EFI guy.
Old Apr 17, 2002 | 09:11 PM
1CanuckVette
Default Re: Porting question, what if...... (65Z01)
Thanks for the reply, now maybe I won't loose as much sleep. :sleep:
:cheers:
To Porting question, what if......
