need help
Old Apr 17, 2002 | 08:30 PM
dave g's Avatar
dave g
Default need help
okay i just ordered a 450 hp 383 I know the guy said the stock injetors would work. but im not to sure about that so what size inj are stock .and he also said the motor comes with a chip .if any body is running this set up give me some injector advice. its a 86 l98 :smash:
Old Apr 17, 2002 | 08:34 PM
qkvette's Avatar
qkvette
Default Re: need help (dave g)
i have similar set up, and i'm running 30# injectors. i've heard that the 23 or 24# stock injectors on your car will work, but i think the 30#s gives you a little bit more room. if you're looking to replace, i think some forum members have bought some stuff from this site :www.fiveomotorsport.com. really cheap price.
good luck. by the way you may want to get into prom burning.
joel
Old Apr 17, 2002 | 08:52 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: need help (qkvette)
#24s would probably get you by, but once they start clogging up you may start running lean.
As stated above. The 3O pounders would definately not hurt. Might need to play with a chip though.
To need help
