Oil pan drain plug
Old Apr 17, 2002 | 08:42 PM
OURRUBY's Avatar
OURRUBY
Spending his inheritance
Cruise-In VIII Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Oil pan drain plug
I saw a Fram commercial for a new oil; pan drain plug that alll you do is hook up a short piece of hose to to drain your oil. Anyone used one of these? I first thought that a bad feature could be a piece of dirt/sludge in the pan could stick in the drain plug and you would loose all the oil eventually. If these things really work, it sure would make oil changes a lot easier, especially if you don't have ramps.
Old Apr 17, 2002 | 08:55 PM
nobodyunknown's Avatar
nobodyunknown
Default Re: Oil pan drain plug (OURRUBY)
I saw it on TV also.
I feel its a waste of money.time. piece of mind,&:bs
You have to jack it up or something,even with the hose you arent able to reach under there & use the hose.
Its nothing new either.
Old Apr 17, 2002 | 09:29 PM
Rich B.'s Avatar
Rich B.
One thing more to drag on the supermarket exit ramp... :nonod:
Old Apr 18, 2002 | 10:36 PM
OURRUBY's Avatar
OURRUBY
Thanks guys. That is just what I figured. I was only curious to see if anyone had really tried one :seeya
To Oil pan drain plug
