How accurate is this reading?
Old Apr 13, 2011 | 03:46 AM
Morv's Avatar
Morv
Cruising
Default How accurate is this reading?
So I was playing around with an Iphone app today that supposedly works as an onboard performance meter for your car. I got curious so I did tried it out. I have a stock '88 except for 3" straightpipe and air filter cut. How accurate do these look?
Old Apr 13, 2011 | 10:21 AM
JackDidley's Avatar
JackDidley
Not too far off but a bit optimistic. Your car should run the 1/4 at 13.9-14.0 @ 98 mph. Depending on air and traction.
Old Apr 13, 2011 | 12:30 PM
STL94LT1's Avatar
STL94LT1
Looks like a bad guess!!
Old Apr 13, 2011 | 06:50 PM
Morv's Avatar
Morv
Cruising
The run I posted above was the best of 4, the others were in the 14.3ish range on the 1/4 mile so I guess I could have gotten a little off that time.
Even tho it might not be right on the money, with the consistency factor it could be useful to test before/after performance of mods without paying the money for a dyno run. just for fun, here's what it showed in 2nd gear to 5k rpm, it read 219hp this time.
Old Jun 12, 2011 | 07:34 PM
thearborbarber's Avatar
thearborbarber
Alot has to do with what the trigger threshold is to start the timing mechanism. If it's adjustable you want it around 0.2g's. This way your staging doesn't set it off. I have a pdf and link to a car and driver report that tested performance meters to the timing lights at a track. I can email them to a you if you like.
To How accurate is this reading?
