Underhood fire, and potential grenade!
Old Apr 14, 2011 | 10:30 PM
93Rubie's Avatar
93Rubie
I do not recommend the "just throw parts" at it theory. This can be very costly and frustrating in short and long term. I have seen this happen. People throw parts at stuff, and it would have been cheaper to have it diagnosed. Granted finding someone who will actually diagnosis something and do it correctly is not easy. I personally like diag. way more than bolting on parts. Diag. is interesting, bolting on parts is boring and at times a PITA.
That being said, I recommend getting a GM Field Service Manual and learning about your Corvette then using the manual as a guide to help diagnosis your Corvette, when things go south.
Old Apr 15, 2011 | 01:28 AM
OkieC4's Avatar
OkieC4
Originally Posted by racerseks
Update:
Got dark on me here in Florida, so waiting till tomorrow. I'll probably use a syphon unless anyone can explain that fuel pump method...
Anyway...tips? suggestions?
Thanks!
Disconnect the fuel return line rubber hose at the fuel pump access plate. It should be the one connected to the rigid line which is at the lwr l/h (7 o'clock) position below the filler neck. Attach a longer hose to a suitable container to the rubber return hose.
You can jumper the terminals (I believe terminals 2 and 3 for a 86) of the fuel pump relay connector, supplying bat voltage to the pump, causing it to run until the jumper is removed. The pump should pump the fuel through the return line at the tank and fill the container.
Old Apr 15, 2011 | 09:51 AM
Toy90's Avatar
Toy90
To answer your question about fuel stabilizer after the fact, no it would not help you. You need to put it in before you stop using it. There is no morning after stabilizer that I know of.
Old Apr 16, 2011 | 09:00 AM
racerseks's Avatar
racerseks
I may very well try this route, so thanks for the tip. Is there a post anywhere that might go through this in detail? I just want to make sure I am thining about it the right way as fas as the "jumper" part. After that incident, I want to make sure there aren't any sparks from making a wrong connection or something. Thanks again!
Thanks!
Old Apr 16, 2011 | 09:43 AM
OkieC4's Avatar
OkieC4
In doing a little more research, I found another thread where Agent86 posted a link to wiring diagrams.....
http://members.shaw.ca/corvette86/En...agram%2086.pdf
Looking at Pg 3 of the prints, you can put 12 volts on Pin G of the ALDL connector and the pump will run. If for some reason that doesn't work, then jumpering terminals E to A at the relay will accomplish the same thing..
Thanks Agent86!
Old Apr 16, 2011 | 10:43 AM
racerseks's Avatar
racerseks
Thanks Agent86!
Thanks...Can you tell me where I'd actually find the pump relay, and how would I get 12v to it?
Thanks again!
Old Apr 16, 2011 | 10:59 AM
ch@0s's Avatar
ch@0s
the ALDL connector is your data connector under the sterring wheel
Old Apr 16, 2011 | 11:30 AM
OkieC4's Avatar
OkieC4
Your fuel pump relay should be on the firewall next to and a little below the w/s wiper motor. If you are going to go there, take the connector off the relay and use a small jumper wire to connect terminals a and e. - pump should run.
If you are going to the ALDL connector, make a longer jumper wire and go from the positive bat terminal or the jump block where all your fusible links are connected to pin g of the aldl.
Old Apr 16, 2011 | 03:17 PM
racerseks's Avatar
racerseks
Hey, thanks for the reply! Most likely, I'll try jumpering at the fuel pump relay. Just to be sure, do I Jumper A and E on the connector, or the relay itself?...or otherwise?
If I get nothing, would this be an indication it's fuel pump related?
Thanks!
Old Apr 16, 2011 | 04:22 PM
ch@0s's Avatar
ch@0s
Thanks!
or wiring
Old Apr 16, 2011 | 06:23 PM
racerseks's Avatar
racerseks
Originally Posted by ch@0s
or wiring
How about on that jumpering question? Would you know?
Thanks for the reply!
