headlight question
Old Apr 16, 2011 | 03:56 PM
craneman61!'s Avatar
craneman61!
Default headlight question
The headlights on my 96 open and close. They have what i call a flutter when opening and closing. I know I have a bad gear in the left motor. When you close it manually, when it is almost closed you can feel it jump a gear. The right one will close and you feel the motor stop. What is causing the flutter? They flutter 3 or 4 seconds and quit. Should I rebuild both sdes or leave well enough alone?
Old Apr 16, 2011 | 04:37 PM
STL94LT1's Avatar
STL94LT1
Do a search on "headlight bushings", they need replaced.
Old Apr 16, 2011 | 08:50 PM
oldalaskaman's Avatar
oldalaskaman
amen
Old Apr 18, 2011 | 05:40 PM
aklim's Avatar
aklim
I would get the bushings and the bronze gear and do them in a set
To headlight question
