Dumb timing question
Old Apr 18, 2002 | 03:53 AM
x_streme's Avatar
x_streme
Default Dumb timing question
what lead do you need to unhook when checking base timing? :confused:
Old Apr 18, 2002 | 08:51 AM
JonM's Avatar
JonM
Default Re: Dumb timing question (x_streme)
Disconnect the EST (electronic spark timing) at the distributor
Old Apr 18, 2002 | 09:10 AM
corvette90's Avatar
corvette90
Default Re: Dumb timing question (JonM)
where ist the connector located, and how does it look like?
can somebody give us wire colors?
thanks
Old Apr 18, 2002 | 10:03 AM
Carl90's Avatar
Carl90
Default Re: Dumb timing question (corvette90)
Don't know the wire color, but the connector is behind the driver side valve cover and near the distributor.
Carl90
Old Apr 18, 2002 | 11:21 AM
jeepie91's Avatar
jeepie91
I am pretty sure there should be a connector sticking out of the large wire harness located above the brake
booster (it might be taped to the harness), I think the wire is brown (could be wrong on color). Seperate the
connector and then set the base timing, you should get an engine light on dash while disconnected.
Old Apr 18, 2002 | 05:24 PM
hotwilzz's Avatar
hotwilzz
it is near the brake booster. if you have a haynes repair manual there is a pic in there
good luck
Old Apr 18, 2002 | 05:53 PM
Bluevette85's Avatar
Bluevette85
It's by the brake booster and wiper motor. You might have to move some wiring harnesses around to find it.
[Modified by Bluevette85, 8:35 PM 4/18/2002]
Old Apr 18, 2002 | 05:59 PM
scorp508's Avatar
scorp508
The wire is brown in my car with a round connector at the end.
To Dumb timing question
