93 Cruise Control
Old Apr 17, 2011 | 04:22 PM
ken93vette's Avatar
ken93vette
Default 93 Cruise Control
The cruise control has never work since i got the car 7 years ago. When you push the cruise button nothing happens, not even a click of electrics trying to work.
I have read on the various threads that there are multiple problems can interfere;
Vacum
Brake Switch
Cruise Module
Cruise Relay
Servo
With the exception of Vacum Hoses which would be the most likely problem part?
I am at the end of finishing multiple projects with my 93 coupe with greenwood package including engine rebuild with comp cam, roller rockers, AFR heads, 36# injectors. It is now in for painting including greenwood scoop, and hood vents.
Ken
Old Apr 17, 2011 | 05:01 PM
ecorse66's Avatar
ecorse66
Here are a couple of links to sites that may give you the info you need. They helped me fix my cruise control, which had the same symptoms.
http://www.vetteweb.com/tech/vemp_10...air/index.html
http://www.corvettefever.com/howto/82001/index.html
In my case it was the 'set' button itself that was not making contact. You can check the cruise switch functions with an ohmmeter by unplugging the under dash connector and moving the stalk switches to their various positions while checking for continuity. Also check the brake and/or clutch switches the same way. Good luck!
Dave T.
Old Apr 17, 2011 | 07:54 PM
ken93vette's Avatar
ken93vette
Thanks for the help. I have generally stayed away from electrical however it looks like i need to by a multi-meter and learn how to use it.
Ken
Old Apr 18, 2011 | 12:14 AM
mtwoolford's Avatar
mtwoolford
subscribed
Old Apr 18, 2011 | 10:36 AM
ecorse66's Avatar
ecorse66
Ken
You can buy one that will do the job for less than $5 on sale at Harbor Freight. Look for their coupons! A flashlight battery powered continuity checker will check out the switches, Just make sure you the ground cable on the car battery is disconnected!
Dave T.
To 93 Cruise Control
