Engine Measurements
Old Apr 18, 2002 | 09:22 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Engine Measurements
To put it quite simply I am very bored at work. I spent a good deal of time yesterday drawing a fairly accurate 2d front on veiw of a v-8. It's very basic right now as it only has the connecting rods and pistons drawn in. No cam or anything like that.
SO to further my drawing, I need some more information.
What are the specs for a stock LT1 cam? Duration, Lift? Also what is the diameter of the base circle?
Also how far upward is the cam from crankshaft? Centerline to centerline would be perfect. Also what size are the timing gears? I know that the cam gear turns at half the speed of the crank gear so I can probably figure it out, but if somebody happens to know that would help out a lot.
I know somebody knows this information, or can direct me as to where to find it.
Thanks.
Old Apr 18, 2002 | 09:28 AM
Nathan Plemons
Default Re: Engine Measurements (Nathan Plemons)
Yes, it's a little cheap looking right now, but it's a good start. I don't think my block would hold up to much abuse right now :)
The JPG kinda washes the colors from the original cad drawing, so they don't look that great, but anyway, this is what I'm up to.
Anybody any good with 3D studio max and know how to animate this?
Old Apr 18, 2002 | 12:01 PM
Arisa's Avatar
Arisa
Damn your as bad as me. No need to take it into Studio if it's still 2D. If you want me to wash it over for a simple animation I will. I have great 2D/3D AutoCad skills & decent Studio skills. What version are you running? R14 or 2000.
Email me the file if you want.
Later
Neal
Old Apr 18, 2002 | 12:13 PM
MrJay's Avatar
MrJay
That is cool you are good at this.
Jay
Old Apr 18, 2002 | 12:15 PM
Nathan Plemons
Default Re: Engine Measurements (Arisa)
It's 2000, and yes I still have it in 2D. Will that work?
http://www.wku.edu/~nathan.plemons/cad/engine.dwg
Ignore my bad skills, it's been a long time since I've played with cad. One drawing has all 8 pistons, with each pair on a different layer.
Animate away if you are so inclined, I think it would be really cool.
Old Apr 18, 2002 | 12:33 PM
Arisa's Avatar
Arisa
me thinks that is a bad link :D
Neal
Old Apr 18, 2002 | 12:42 PM
Nathan Plemons
hmm, worked for me. You have mail.
Old Apr 18, 2002 | 01:00 PM
Nathan Plemons
Here is my 3d piston
Old Apr 18, 2002 | 02:39 PM
C4TOMCAT's Avatar
C4TOMCAT
Nathan:
I have an lt1 on the engine stand in bare block form now. what demensions do you want. also have all the gears, crank, came etc layed out for installation. Tell me what you want in an e-mail and I will return the info to you tomorrow night (Fri). Just let me know. C4TOMCAT
Old Apr 18, 2002 | 03:32 PM
Arisa's Avatar
Arisa
Default Re: Engine Measurements (C4TOMCAT)
Here's ya a quickie :D
Neal
Old Apr 18, 2002 | 11:21 PM
Nathan Plemons
Well here it is so far. Now I just have to figure out a crankshaft.
Old Apr 18, 2002 | 11:42 PM
Vette9d1's Avatar
Vette9d1
Thats a pretty impressive drawing! :yesnod: How long does something like that take?
Old Apr 19, 2002 | 04:56 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
That looks pretty good. Maybe you could just find a way to eliminate the crankshaft and get rid of all that rotating weight. A stroker motor would be a lot cheaper without it too.
Old Apr 19, 2002 | 05:31 PM
C4TOMCAT's Avatar
C4TOMCAT
Nathan, sent you email with info you requested. hope it helps, let me know if more is needed and what.
Old Apr 19, 2002 | 05:38 PM
MrJay's Avatar
MrJay
Nathan it must be really slow at work for you to do all that fine work you have done it AUTOCAD.
This cool stuff you have done.
Jay
To Engine Measurements
