what should my idle be....
Old Apr 19, 2011 | 07:15 PM
jjjjwiz's Avatar
jjjjwiz
Default what should my idle be....
I want to know what the idle shold be on my 1984 vette with an automatic?? thanks
Old Apr 19, 2011 | 07:32 PM
SunCr's Avatar
SunCr
Same as any GM fuel injected motor: 50 +/- Actual RPMS from Targeted in Drive; 100 +/- Actual RPMS from Targeted in Park/Neutral. You need a scanner. Targeted will vary with Coolant Temp so if it doesn't seem right, look at the Sensor Value too.
Old Apr 19, 2011 | 09:02 PM
DBo's Avatar
DBo
Mine idles, when warmed up, at 700 in drive. Good bit higher until fully warm.
To what should my idle be....
