would converting my 84 to tpi be hard? what would i need to change or add to harness, does cpu need to change as well as fuel pump? any input would be great.
A couple guys on here have done it with good results. Stock TPI wont do much for you but aftermarket TPI will. I think 383 went with a Superram and maybe QWS did a Holley SR. I may have the wrong user names here but both have been done.
what about wiring?i was running high 12's before i took it apart w/ a carb but now want to go with FI. How is the wiring conversion with that superram?
388 Roller with a HSR here. No major changes to the wiring harness. I used the main harness in the 84. I have a 40 some page thread on SV about the change.
I went from the x-fire to a carb and then to the SuperRam. Since my harness was pretty much out, I didn't use much of the stock stuff with the Accel gen 6 computer. New fuel pump needed. qws has the ideas you probably are looking for.
