LT4 with automatic tranny swap
Eric Fischer performed a swap around Mid 2002 for Bill Fischer. He put an automatic transmission behind an LT4. Does anyone have any technical specs, web links, documentation, or etc on how this was done?
I don't care if people think it's stupid. that's not the point of this post. I would just like to see what was involved for the swap to work, especially any wiring changes.
the M6 to A4 swap would be pretty straight forward.
Others may remember how Eric Fisher did the swap exactly.
They will chime in with details.
Brian
DO the reverse of a auto to ZF6 swap.Use the link for some Help.I might have a auto brake pedal and console shifter.
I would use a 700r4 with a Kick down cable.Youll need a auto driveshaft and tranny to diff connector .
http://www.cisdi.com/
All stock factory parts and as noted ,mods to the console to fit the shifter
Thanks. My 91 has a modified 700r4 already in it. The original L-98 has been removed, but everything else is still there.
Thanks for the link!
Thank You
Thanks for the info.
Lt1
Thanks for the "heads-up."
