Granatelli MAF & LT4
Old Apr 18, 2002 | 06:25 PM
sherpabob's Avatar
sherpabob
Cruising
Default Granatelli MAF & LT4
Will the Granatelli MAF get me any increase in HP on a LT4 and if it will who's got the best price? What about a larger throttle body? :jester
[Modified by sherpabob, 6:32 PM 4/18/2002]
Old Apr 19, 2002 | 12:49 AM
vader86's Avatar
vader86
Default Re: Granatelli MAF & LT4 (sherpabob)
a larger TB wont help until you port some things open(heads,intake), the Granatelli had a good price (i thought) in a ZIP catalog i saw. But i have no experience with them.
Old Apr 19, 2002 | 09:47 AM
GS470's Avatar
GS470
I'm NOT speaking from experience, but I've heard the Granatelli MAF is complete waste of $$. Don't believe the claims.
I've been told a 52mm TB probably won't do much until you start making mods like a cam, heads, etc... I'm going to put a 52mm TB on mine this summer, but I'm not expecting big gains.
[Modified by GS470, 7:47 AM 4/19/2002]
[Modified by GS470, 7:49 AM 4/19/2002]
Old Apr 19, 2002 | 01:06 PM
silver & red CE's Avatar
silver & red CE
IMHO, save your money and do gears, I did and I love it. 4.10 gears have to be the best thing I did to my Vette. I should have done it before the cat back.
Eric
Old Apr 20, 2002 | 12:52 PM
khornet's Avatar
khornet
From: Phx/but its a dry blast furnace kinda heat AZ
If you read some of the experiences in the Tech Tips section. Some of the guys are claiming actual dyno proven HP increases. Take a look on eBay, you'll find them for about $270
Old Apr 21, 2002 | 11:18 AM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
There is a new LS-6 Mass Air meter that is calibrated for the LT-1/LT-4 cars availible, I believe that Granitelli makes this. I have a friend in the area that owns a shop called Speed Inc. they have a chassis dyno and the smallest gain they have seen with one of the LS-6 meters is 8rwhp on a close to stock bolt on car and as much as 14rwhp on a 396 stroker motor car. I believe these sell for under $175 (Im not positive though) give them a call at 847 891-0767 and ask for Tom or Larry, they can give you all the info you need.
Good Luck
Mike
Old Apr 21, 2002 | 01:20 PM
nickd's Avatar
nickd
Default Re: Granatelli MAF & LT4 (MVR 155)
I picked up one of these yesterday from Larry @ Speed Inc. Going to test it at the track next Sun.
from what I understand they are the only ones who carry this MAF right now.
Great guys to do business with.
[Modified by nickd, 8:49 AM 4/22/2002]
Old Apr 22, 2002 | 10:28 PM
No Go's Avatar
No Go
Default Re: Granatelli MAF & LT4 (nickd)
Quite interested in your results.
My last dyno run we hooked up to a vacuum source on the intake and measured 1.5 inches at 6400 rpm on my stock LT4 intake tract except K+N and cut lid. Dyno operator said that on race motors they like to see .5 or less but 1.5 is certainly acceptable-but if a MAF would help with no negatives then...
To Granatelli MAF & LT4
