What cylinder heads does your car have?
GM part number?
The bolts may fit but if the ports don't match up you won't be getting the flow you're looking for.
About any header that fits the car should work the ports are small.
Some like using shorties for an Lt1 on the L98.
Check with Summit and see what they have.
Keith if you use the stock iron heads with straight plugs the stock headers will need dimpling to clear the plugs I thought of using the 113's on my 400 small block but I think the fire ring on the head gaskets would hit the coolant passages in the heads If you have a set of 400 head gaskets and your stock 113's maybe you could measure and see if the piston holes fit.I would be interested to know.My heads are still bolted to my motor I took out.Thanks,Steve
