Brakelines from ABS system???
Old Apr 25, 2011 | 09:52 PM
joseph p's Avatar
joseph p
Default Brakelines from ABS system???
The brakeline broke under the car just where it comes out of the floor compartment with the ABS. I unhooked the line from the ABS and cut the line a little ways forward of the hole. I can't seem to push or pull the line so I could repair or replace it. I unbolted the bottom of the compartment and dropped it down but still no movement?
Has anyone done this job before?
Old Apr 25, 2011 | 11:15 PM
leesvet's Avatar
leesvet
Sure its the same line? Steel line right? I'm sure there are grommets in the bulkhead or even bulkhead fittings.
Theres a bunch of them that exit that ABS compartment...
