Help !! Warning lights...
Old Apr 18, 2002 | 11:01 PM
T1Kilr's Avatar
T1Kilr
Default Help !! Warning lights...
On the way home the Service ASR and Service ABS lights came on. I got home, shut the car down, waited for a couple minutes and restarted it. The lights didnt come back on. What should I be looking for? I remember a post similar to this but I cannot remember what the advice was... Any help would be appreciated.
Thanks..
Old Apr 18, 2002 | 11:14 PM
jfb's Avatar
jfb
Default Re: Help !! Warning lights... (T1Kilr)
Those lights came on because one or more sensors reported a failure of some kind and the computer stores these error codes. You can recover the stored error codes and they point to were to start looking.
Old Apr 18, 2002 | 11:17 PM
T1Kilr's Avatar
T1Kilr
Default Re: Help !! Warning lights... (jfb)
How many start cycles are the codes kept?
Old Apr 19, 2002 | 12:53 AM
c4cruiser's Avatar
c4cruiser
Check the fluid level in the master cylinder. I had that happen at an autocross last year, so I checked the master and it needed about 3 oz of fluid. Topped the master off and no more lites.
The expensive fix can be a faulty electronic brake control module. Pull the codes and post them (if any).
Old Apr 19, 2002 | 07:09 AM
T1Kilr's Avatar
T1Kilr
ttt
anyone know how long the codes stay in memory?
[Modified by T1Kilr, 6:09 AM 4/19/2002]
Old Apr 19, 2002 | 07:16 AM
wilb3's Avatar
wilb3
Mine did that once after going over a series of unavoidable bumps. They went away after shutting the car off and restarting. After that, I didn't pursue it- haven't had any problems since(KNOCK ON WOOD!)
Old Apr 20, 2002 | 01:10 AM
kbklt1's Avatar
kbklt1
My bet is on the brake fluid level in the master cylinder, I looked at mine 2 times before I realized the line I was looking at was the mold line and not the fill line :crazy:
Afterwards no warnings anymore :)
Old Apr 20, 2002 | 01:32 AM
okinawa86vette's Avatar
okinawa86vette
Going off memory, I believe it's 50 times. It's been a while since I had asked the dealer, so that number may be wrong. Give a chevy dealership service department a call and they'll tell you the number for sure.
Old Apr 21, 2002 | 01:13 AM
behnevette's Avatar
behnevette
According to my 92 Service Manual, the codes stay in for 100 cycles.
I don't know if that applies to a 93, however.
[Modified by behnevette, 12:14 AM 4/21/2002]
To Help !! Warning lights...
