Question on plugging a muff pipe to lower resonance
Old Apr 18, 2002 | 11:57 PM
drive it's Avatar
drive it
Default Question on plugging a muff pipe to lower resonance
I remember reading about a few folk who plugged one outlet on each muffler to lower resonance. What did you use? I want to find something that I can also remove easily. I had to ask this after droning around today on slow speed roads-right in that resonace rpm band with my borlas.....Huh? Whatcha say?........
I tried temporarily duct taping over one outlet each when I got home and it was a noticable improvement. But duct tape on the outside of a tailpipe is a little tacky lookin....much worse than someone's custom air intake (sewer pipe and dryer vent-:cool:). :D
Old Apr 19, 2002 | 04:47 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Default Re: Question on plugging a muff pipe to lower resonance (drive it)
There's always a potato but its probably more tacky than the duct tape.
I wonder if you could get a freeze plug that would work or a cast iron pipe plug.
Old Apr 19, 2002 | 05:12 AM
DON M's Avatar
DON M
A plumbers "test plug" in the appropriate size would work.
Old Apr 19, 2002 | 11:41 AM
skilawyer's Avatar
skilawyer
a raquetball painted black fits in mine er, i mean in this guy's car that i know. ;)
Old Apr 19, 2002 | 01:23 PM
ralph's Avatar
ralph
Default Re: Question on plugging a muff pipe to lower resonance (skilawyer)
I use a plumbers pipeplug; one in each muffler. It works great. Just a wing nut to tighten or remove. Does quiet the car down a bit.
Old Apr 19, 2002 | 02:13 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
I use an exhaust pipe reducer with a metal sears lawnmower gas cap riveted to the small end. It slips inside tight comes out for the track. I put a small long bolt across to grap with pliers to get them out. They do pop out sometimes at WOT, but the tips of the B&B hold them.
I tried the pipe plug in the B&B and could not get the fit I needed!
Old Apr 19, 2002 | 02:21 PM
Raysur's Avatar
Raysur
Default Re: Question on plugging a muff pipe to lower resonance (PeteL)
If you want to lower resonance you need a tip that is angled towards the ground or "turn downs." This way the power is always there.
To Question on plugging a muff pipe to lower resonance
