84 won't turn off
Old Apr 27, 2011 | 02:49 PM
84VaVette's Avatar
84VaVette
Default 84 won't turn off
I had this problem a few years ago, ended up being the ignition switch, I also changed the ignition lock as well since I they key was being difficult to remove from the column ( that fixed the problem there as well ). Problem came up again. Car starts fine. Everything works as it should when the key is in each postion, with the following exception :
In the off and acc position, not only does the car keep running, but the dash stays lit up as well.
I've tried three different switches ( old one, two new ones , and it does the exact same thing with each. I've checked each switch being in the proper position when putting it in, same thing. I even tried putting it in the wrong position, but cannot getting any result other than car continuing to run, and dash staying lit up. I even replaced the ignition lock again, no change in results. Suggestions? Car is an auto.
Old Apr 27, 2011 | 06:15 PM
84VaVette's Avatar
84VaVette
bump
Old Apr 27, 2011 | 07:28 PM
myk7's Avatar
myk7
Is the car's ignition stock? Does the radio turn off correctly in "off" and back on again in "acc"?
Old Apr 27, 2011 | 07:35 PM
84VaVette's Avatar
84VaVette
Yes, other than the car continuing to run, everything else acts just as it should. The transmission locks when it's off, radio goes off properly, antenna goes down, etc.
Old Apr 28, 2011 | 01:01 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
M.A.D. enterprises (not Mid America Designs) has a kit to eliminate this. it is a sneak circuit through your alternator.
THey put a diode in the alternator light circuit I think, and it stops powering the ignition through the alternator. Your 84 has the early style alternator, and those sometimes exhibit this fault.
I think it's MADelectrical.com
Old Apr 28, 2011 | 08:26 AM
ecorse66's Avatar
ecorse66
If this is your problem, here's a link that may help.
http://www.msdignition.com/page.aspx?id=3296
MSD uses a 100V/1A diode
You should be able to use a 1N4004 diode (3 for $1 @ radio Shack) which has a higher voltage rating.
http://www.radioshack.com/product/in...ductId=2036270
Of course, the run-on may be due to a defective regulator in the alternator, or a wiring error in the charging circuit. The diode would be a cheap way to try and localize the problem.
Good luck, and be sure to let us know what works!
Dave T.
Old Apr 29, 2011 | 03:16 PM
84VaVette's Avatar
84VaVette
Would this also account for the dash staying on all the time?
To 84 won't turn off
