Designed for 1.6 rockers would be .566 llft?
Would like ported heads for sure, make good midrange power.
Yes, the lift is quoted with 1.6 rockers. A friend of mine was running this camshaft with AFR 190 heads. It ran real well and was easy to tune. It should also work pretty well with stock heads.
C4 of Year Winner (appearance mods) 2019
With unported heads, the extra lift won't get much and you'll probably have to change springs every so often. I'd go with ~.525" lift w/o porting.
Sometimes, you can get flow "stall" with too much lift for head characteristics. Local guy said he couldn't get much more out of 113 heads above .525" lift -- even with porting. XFI cams are aggressive enough, I wouldn't pick it unless racing for 1/4m times.
Which Cam would you recommend with stock heads. I do have 4:10 Gears and Magnaflow mufflers.It's my daily driver and don't want it to be too aggressive.
"Hot Cam"...Seems that it allways goes back to it.Old faithful...I believe your right.Great old technology Cam.How much HP increase, approx., should I realize with stock heads?
Enough that you'll feel it. Low enough that you'll either want more or feel you spent too much (with the install/tune). More satisfactions with head improvement.
