close loop stumble
Old May 1, 2011 | 01:18 AM
getnakd's Avatar
getnakd
Default close loop stumble
1991 383 44lb trickflow injectors. had tune. before and after tune car would misfire after cloosed loop and then bog down at wide open throttle for a couple of seconds then come out of it. tried injectors timing, valve adjust, car made 340rwhp and 410rwtq with slipping over priced ram c4 conversion clutch
Old May 1, 2011 | 07:20 AM
WW7's Avatar
WW7
You need to hook it up to a scanner, this should help point you in the right direction..If its doing it in closed loop only then it may involve one of your sensors since most of these don't come onto play until the car reaches closed loop.. My first guess would be an 02 sensor but it could be as simple as a coil , or Ignition control module malfuntioning after it warms up, but a scan may tell you where to look.....WW
Old May 1, 2011 | 01:28 PM
getnakd's Avatar
getnakd
hooked up solus and watched data all seems normal, o2 says the same in or out of closed loop
Old May 2, 2011 | 12:11 AM
DVNCI's Avatar
DVNCI
Clean your MAF
Old May 2, 2011 | 03:23 AM
bill mcdonald's Avatar
bill mcdonald
Let me know if you ever find that MAF. lol.
Whats the deal on the exhaust? Stock, headers?
Old May 2, 2011 | 11:13 PM
getnakd's Avatar
getnakd
sorry no maf. I also noticed when temp reads 185 the car has big flat spot. any ideas? has headman headers, no cats, (live in north dakota) magnoflow mufflers real duals.
Old May 2, 2011 | 11:36 PM
leesvet's Avatar
leesvet
something with the tune is way wrong...sounds like starving for fuel...or too much air, same thing in many ways.
Go pull some plugs and see what they can tell you. if its been lean, or rich you'll see it on the insulator.
Old May 3, 2011 | 01:11 AM
DVNCI's Avatar
DVNCI
Argh yeah didn't notice it was a 91 the first time!
Something is probably off in the VE table in your tune
Old May 3, 2011 | 01:42 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Was it bone stock before the tune? No exhaust mods? Too little detail.
Old May 3, 2011 | 10:47 AM
DVNCI's Avatar
DVNCI
Also that is way more injector than you actually need - I assume the tune has been adjusted for that?
Old May 3, 2011 | 11:52 AM
383vett's Avatar
383vett
If you can, get a hold of a wideband. It'll tell you in a second what your problem is if it's afr related.
Old May 3, 2011 | 11:47 PM
getnakd's Avatar
getnakd
I notice my fuel line is about 1 inch away from my headers. do you think that it might be causing vapor lock symtom.
Old May 3, 2011 | 11:52 PM
getnakd's Avatar
getnakd
forgot to tell the whole story 383 comp heads cam 556-566 lift 344 354 duration 44 injectors holly stealth ram bbk 58mm throttle all roller. 12.1 keith black pistons with long stroke stroker kit.
To close loop stumble
