help
Old May 1, 2011 | 01:29 PM
gregs86's Avatar
gregs86
Default help
i just got my new motor running decent but i notice water coming out of the head studs i have by-passed my throttle body maybe i did not do it right could that be it theres no white smoke so dont think it is a head gasket its leaking on both sides dont know if its leaking under the valve covers please tell me what it could be
Old May 1, 2011 | 01:44 PM
mmracecars's Avatar
mmracecars
did you coat the studs with thread sealant before they were screwed into the block
Old May 1, 2011 | 01:48 PM
gregs86's Avatar
gregs86
yes used thread sealer i even went back and looked at some pics to make sure
Old May 1, 2011 | 01:54 PM
383vett's Avatar
383vett
What head studs? Do you mean the bolts below the exhaust manifolds or under the valve covers? Does your motor have studs?
Old May 1, 2011 | 01:55 PM
mmracecars's Avatar
mmracecars
weve had that issue before,cant explain why,but used some stuff made by moroso called ceramic seal,and stopped the leaking.
mike
Old May 1, 2011 | 01:58 PM
gregs86's Avatar
gregs86
yes i used studs instead of bolts
Old May 1, 2011 | 02:01 PM
383vett's Avatar
383vett
mike
I've used a product called irontite. They have a superduty one used with just water and another one that is compatable with antifreeze. They are both heavy duty sealers. The op might want to try this product.
To help
