85 A/C compressor help
Old May 3, 2011 | 08:34 PM
bud315's Avatar
bud315
Default 85 A/C compressor help
I am trying to replace the a/c compressor in my corvette. I tried to remove it but I ran into a problem where I couldn't get a few of the bolts out of the bracket. I was wondering how to remove it. Do I have to take the valve covers off so I can remove the bolt, or do i have to remove the whole mounting bracket to remove it. Thanks for your help
Bud
Old May 3, 2011 | 08:51 PM
paulmeisterpk's Avatar
paulmeisterpk
I removed the whole mounting bracket when I did mine. It wasn't that bad. I had the same problem removing the AC as you when I changed my heads.
Old May 3, 2011 | 09:31 PM
bud315's Avatar
bud315
do you think you could tell me how to get that mounting bracket out? that would be really helpful thanks
Old May 3, 2011 | 10:51 PM
Hooked on Vettes's Avatar
Hooked on Vettes
This thread should answer your question.
http://forums.corvetteforum.com/c4-t...r-removal.html
Old May 3, 2011 | 10:53 PM
paulmeisterpk
Originally Posted by rodj
You just undo the nuts on the waterpump studs and slide the bracket off without disturbing the WP.
Disconnect any compressor braces , remove the 2 nuts , undo the long bolt at bottom of compressor while pulling whole lot foward until bolt comes free.
Slide off WP studs and you have the whole lot out.
That sounds about right. I can't remember exactly what bolts I removed, but that is probably it.
To 85 A/C compressor help
