RE: Fuel injection
Old May 4, 2011 | 07:11 AM
sunnfish's Avatar
sunnfish
Default RE: Fuel injection
I have a 86 with some mods, bigger cam, headers nothing real major. I was looking into an ajustable fuel regulator. Does this make any horse power improment?
Old May 4, 2011 | 07:51 AM
87 vette 81 big girl's Avatar
An adjustable fuel pressure regulator is a powerful tuning tool if you are racing or have made major engine mods for more torque and horsepower.
If you are just cruising lightly or driving to a car show once in a while an adjustable fuel pressure regulator is not likely needed.
Old May 4, 2011 | 02:43 PM
racebum's Avatar
racebum
better injectors would be the way to go along with tuning the car. if you swapped cams you should have the car tuned and the oem 86 injectors are just not a good choice compared to the newer stuff FIC is selling
Old May 4, 2011 | 02:57 PM
pmihaltian's Avatar
pmihaltian
Slingshot
$60 at Ecklers. Also available at most Corvette parts houses.
http://www.ecklers.com/corvette-high...1985-1991.html
Old May 4, 2011 | 03:24 PM
leesvet's Avatar
leesvet
there is no real benefit to an adjustable regulator with stock injectors...
get some fuel system upgrades, then you can use the FPR to fine tune. Paying for a "tune" will tell you where the FP should be...as long as you have good inj and leave it alone after that,.
To RE: Fuel injection
