Paint Issue
Old May 5, 2011 | 03:03 PM
Jacked66's Avatar
Jacked66
1st Gear
Default Paint Issue
I own a 2004 white corvette. I have somehow managed to get some deep scratches on the front of the car.
Is there any way I can fix this without painting the whole car
Any help would be appreciated.
Old May 5, 2011 | 03:16 PM
CROOZ1N's Avatar
CROOZ1N
I also somehow managed to get a friggin scratch on the nose of my 93 last week. I think i'm gonna try the Dr. Colorchips system.
Old May 6, 2011 | 02:01 PM
turbotim23's Avatar
turbotim23
Are the scratches just in clear or deeper? More than likely they are just in the clear. You more than likely have to wet sand the scratched area with a block using very fine sand paper like 1200 grit or finer grit then rub it out. I didn't like the amount of orange peal my car came with from the factory I wet sanded my car and rubbed it out it looks much smoother now. I was surprised at the amount of clear on there and how much I was able to level it out. Even if your scratches are deep enough to go past clear they could still be spot sprayed and rubbed out in just a small area. Good Luck Tim
To Paint Issue
