whats everones ride height.
Old May 6, 2011 | 07:52 PM
COPO's Avatar
COPO
Default whats everones ride height.
Just curious at to what ride height is front and rear on some cars, stock an lowered. Measuring from the ground to the highest part of the wheel well arch.
Old May 6, 2011 | 07:55 PM
pologreen1's Avatar
pologreen1
Mine looks like it's got the Z71 package from the factory.
Old May 6, 2011 | 08:03 PM
RRRR's Avatar
RRRR
25 3/4 front, 26 1/4 in the rear. Coil Overs on the front and won't go any lower wth a 10" spring. 275/315/17 tires.
Old May 7, 2011 | 08:58 AM
COPO's Avatar
COPO
If stock I would like to know the measurement.
Old May 7, 2011 | 09:00 AM
COPO's Avatar
COPO
That's about where I was at before I changed a few things.
Old May 7, 2011 | 09:44 AM
Aardwolf's Avatar
Aardwolf
I took a few notes while working on mine.
28" front fender stock.
Lowered = 26 5/8" with stock diameter tire.
26 1/2" as it is now with a with smaller diameter tire.
Old May 7, 2011 | 10:16 AM
VETTEHIGH's Avatar
VETTEHIGH
At my lowest points from the ground:
Rear: 3.75 inches
Front: 2.75 inches
Old May 7, 2011 | 10:47 AM
FWC's Avatar
FWC
St. Jude Donor '13, '15-'16,'18 thru '25
Been about a month with new front spring and 4 new Bilsteins 27.5 front 28 rear with 255/45/17 and 285/40/17 tires new as well.
Old May 7, 2011 | 11:23 AM
aboatguy's Avatar
aboatguy
My verts been lowered for about 5 years
Currently 25 '1/2" front and 26 1/4" rear
Still have the factory x brace and seems to be fine after all these years.
(was lower when on factory sawblades been on C5 five spokes for a couple of years and had to raise it a little for tire clearance in the wheel wells)
Now if there was a performance air or hydraulic system that was fx3 compatable I'd be able to go lower and still daily drive it...
Old May 7, 2011 | 12:32 PM
tequilaboy's Avatar
tequilaboy
26 1/4" front, 27" rear with tall 255/50R17 tires.
Old May 7, 2011 | 01:18 PM
383vett's Avatar
383vett
2 fingers in front, 1 1/2 in back. During launch 7 fingers in front.
Old May 7, 2011 | 01:59 PM
ROME's Avatar
ROME
26 3/8" here.
Old May 7, 2011 | 06:38 PM
COPO's Avatar
COPO
Originally Posted by ROME
26 3/8" here.
Havent seen that name in a while. Car looks good man.
Seems most are 25 1/2 to 26 1/2 lowered and 27-28 stock. I measured mine and I'm 24 3/4 front and 25 3/4 rear and I dont want to go any lower. I like the way it looks and not changing it.
Old May 7, 2011 | 07:22 PM
nutz4c4's Avatar
nutz4c4
Old May 7, 2011 | 07:25 PM
LD85's Avatar
LD85
front 26" rear 27"
Old May 7, 2011 | 07:33 PM
JackDidley's Avatar
JackDidley
26" Front 27 5/8 rear. No idea why but its been like that a long time. Back tires are 1/2" taller than the front.
Old May 7, 2011 | 08:47 PM
LD85's Avatar
LD85
I guess I should have answered, " whatever I want it to be",, thanks to QA1 coilovers
To whats everones ride height.
Old May 7, 2011 | 08:56 PM
COPO's Avatar
COPO
The reason I ask for these numbers is I have a couple ideas rolling around in my head. At the shop we had considered dropped spindles, but the cost would be to much to produce because of the way the spindle is made. 2nd is to build a k member to lower the car and maybe mount C6 front suspension. Its just a thought
Old May 7, 2011 | 09:51 PM
leesvet's Avatar
leesvet
its easier than that.
Spring arc holds LOTS of inches....
I went to a flat rear spring (very fast rate 499lbs/in) but stiff, and that alone dropped the rear end 3". The more arc the spring has, the higher the body rides off the chassis. Its a combo downside too...the higher it sits the looser the cornering and more body roll, and the more comfortable the ride the softer/slower/taller the spring. Rears vary from 230 lbs to 500 with about 5 inbetween.
Fronts only have a 20 or 40 lb difference for converts or coupes or GS packages.
Unfortunately there are few, if any choices for the front.; IF someone were to re-engineer a front spring, even steel, that would lower the front as well.
If someone would mfg a rear spring with a slower rate, that would be really really nice as well...
its currently like riding in a big go-cart with the flat springs and shims moved over...no liquids allowed inside while moving.
Old May 7, 2011 | 11:11 PM
COPO's Avatar
COPO
Did you take that half shaft out yet and see how your C4 floats????
http://forums.corvetteforum.com/c4-t...refurbish.html
