I have a '92 LT1 and am entertaining the thought of putting a performance chip in her to bump the HP up a bit. Just wondering what something like that would cost, would it really be worth it, or would it just cause more problems than it's worth? Anybody got any comments or suggestions? Thanks.
Okay, I'll go against the grain here and tell you to go for it. Decent tuners such as PCM for Less http://www.pcmforless.com/index.php?...e&Itemid=199or
Madtuner http://madtuner.com/ and others are so familiar with LT1's that they can commonly send you a mail order tune that will add an additional 10 to 15 HP for around $150.
While that may not be enough for the seat of the pants dyno to register I challenge you to find that much horsepower for the price with any other mod.
Add a low temp thermostat and have the tuner adjust the fan on/off temps at the same time for a cooler running engine and to me the price is a bargain, just my take of course.
tech, I don't think he is talking about that kind of chip. What you describe is a semi custom burn. That kind can be worth the $$$. I think he is asking about the value of a "one size fits all" which, IMHO are not worth the $$$.
You may be right Muffin, if I misunderstood and iin fact the OP was thinking of Hypertech or something similar I would agree with others that he should save his money.
The mail order chip/tunes I mentioned are about the same price and I have seen dyno results that show they deliver.
For the price, the mail-order chips can work wonders...
The generic chips like hypertech are only good for changing fans, mild alterations in the way the motor runs, not necessarily making it better..just different.
The custom chip, made based on a description of your motor, is much more suited to your motor. Exactly like buying a suit off the rack, or having one tailored...
This is exactly what I did. $150 for the chip,a 160 t-Stat and I burn 91 octane or above. pretty cheap HP. I told him what I wanted to do and he fixed me up.
I've used a couple of different (LT1) mail order tuners before I found Ed Wright....(Phil from AI recommended him when I started my build and I should have listened)
Some in house tuning can get you more, a mail order will only be so good.
honestly the factory tune is not bad, unless youre going to do other mods why bother really. 10-15hp gain and nothing else is a waste youll never feel it.
