I am trying to see if I can squeeze my car through local emissions.It is an '89 with headers, no cats, and emission equipment disconnected. I know the easy response would be to say "you can't pass emissions with no emissions equipment", but the car is really not that far from passing. I am looking for tips and tricks.
Our local test checks only Hydrocarbons and Carbon Monoxide. Last week, my results of the first test were:
So this morning, I added a bottle of alcohol to a 1/4 tank of gas and headed back to the testing station. Results today:
HC: 222ppm (220) FAIL
CO: 2.51% (1.20%) FAIL
Improvement in CO but worse in HC.
I am new to emissions, in the past I have always had cars that are exempt so I have never worried about all this. If anyone has any tricks of the trade to get this thing through, I'd appreciate it.
give the tester $50 and have him use an air hose on his machine, dont know if that still works, the other way used to be to give your car a vacum leak, dont think that one works either......nomo
Reason: I really should proofread.
Throw a cat in the system. It'll clean it right up. Replace it with a test pipe after you pass. This is nothing compared to what us Californians have to put up with.
