Vacuum hose/tube question
Old May 10, 2011 | 11:43 AM
kyyote's Avatar
kyyote
Default Vacuum hose/tube question
I have tried looking at the diagrams and they didn't help me. I am not a mechanically knowledgable person. I used to be ok, but in the 40 years since I used to work on cars, they have left me behind. My 1985 has a bit of a surge in the idle. The vacuum lines are old and weak, and I already replacec the cruise control line because it wasn't able to hold speed. I just had plugs put in and if anything the idle is even less smooth than it was. So, I got to looking around and found an open Vacuum line? I think, anyway. I am not sure if these pictures will post, as they are large, but I will try, and if nothing else the links will work. There are three pictures from the passenger side, near the firewall. I am hoping someone can tell me what the line is, if it needs to be connected to something, and if not, does it need to be capped.
