need help with air bag light
Old Apr 20, 2002 | 10:50 AM
TGlovka's Avatar
TGlovka
Default need help with air bag light
My “infl rest” light came on this morning in my 90, I check for to see if any codes were set but didn’t find any? I remember Seeing something about the “infl rest” light but can’t seem to find anything.
Old Apr 20, 2002 | 10:54 AM
devilfish's Avatar
devilfish
Default Re: need help with air bag light (TGlovka)
there are som censors that need to be clean up. One is just behind the battery. Hade the same probleme on my 91, cleand the censor behind the battery then the ligth whas gone :) Dont know where the other censor are located..
Regards
Old Apr 20, 2002 | 11:04 AM
x_streme's Avatar
x_streme
the colision sensors on a 90 were kind of poorly designed. you need to pull the sensors, clean them and put a thin coat of dielectric grease in between them and the car when you reinstall. i think there is a description in the tech tips section.
Old Apr 20, 2002 | 11:13 AM
DON M's Avatar
DON M
It is a grounding problem. The accelerometers for the air bag deployment are a problem in every 1990 Vette.
Old Apr 20, 2002 | 02:11 PM
VAHROOM's Avatar
VAHROOM
Default Re: need help with air bag light (DON M)
Maybe this will help. I had mine off for a wink but the b@$t@r% came back.
https://www.corvetteforum.com/techti...D=83&TopicID=2
[Modified by 90_roadster, 12:13 PM 4/20/2002]
Old Apr 20, 2002 | 03:15 PM
RoadKingsRule's Avatar
RoadKingsRule
TGlovka,
Sooner or later, I think all 90s will do this. Most probably it is the AB sensor on the front right. It is located on the frame rail under the AC Condensor and water drips on it causing corrosion under the sensor and on the frame. Call your Chevy dealer and ask if they will run a copy of Dealer Service Update Bulletin 90-436-96. It covers the tests and fixes. REMEMBER TO DISCONNECT THE AIRBAG PRIOR TO BEGINNING WORK!!! The exact repair proceedure is covered in the service manual. Good luck!
Steve
Old Apr 20, 2002 | 04:53 PM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
Default Re: need help with air bag light (RoadKingsRule)
How did I know it was a 90 model before opening the thread :rolleyes:
The tech tip works, just be patient. It took me an hour just to reset the system and get it right after I cleaned and re-installed the sensors. Be sure NOT TO USE A METER OF ANY KIND on the sensors. It can set the airbag off.
Old Apr 21, 2002 | 11:14 AM
TGlovka's Avatar
TGlovka
Thanks guys, I'll try cleaning the sensor. Sound likes the problem I had to drive her in the Rain this week.
:eek:
To need help with air bag light
