Need help identifing interior parts
Old May 10, 2011 | 08:43 PM
prodjbm's Avatar
prodjbm
Default Need help identifing interior parts
I just purchased my first vette 1985 and my interior was pulled apart for new carpet and seats recovered. I have a few parts that I cant figure where they go. can anyone help me with the parts in the link below. If you click on the picture it makes it bigger and I nu,bered them for ease of refernce.
http://s679.photobucket.com/albums/vv156/prodjbm/Vette/
Thank you
Bill
Old May 10, 2011 | 10:00 PM
lwhipple's Avatar
lwhipple
5th Gear
the easiest way would be to go to corvette america. they have compleate parts breakdowns of the interiors for you.
Old May 10, 2011 | 10:04 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Here you go.
That is for the bottom seat mounts to to hide the metal mounts. Front mounts on seats.
These look like your hush panels under your legs when your in the car. Bottom of dash.
This is for your door panel behind the door handle
Old May 10, 2011 | 10:06 PM
CorvetteMike2024
Corvette Enthusiast
Im guessing on this one. Maybe door panels?
Old May 10, 2011 | 10:08 PM
CorvetteMike2024
Corvette Enthusiast
I have no clue about this. Maybe battery hold down?
No clue on the rest
Old May 10, 2011 | 10:11 PM
CorvetteMike2024
Corvette Enthusiast
Here are the rest of the pics. Good Luck.
Mike
Old May 10, 2011 | 10:34 PM
prodjbm's Avatar
prodjbm
Mike,
Thank you so much for taking the time to ID those parts. I think you are right on the battery hold down since there is a brand new battery in the car and the cruise control canister is just sitting on top of battery and the brace that bols to the frame and the hood latch is not bolted either.
Thanks again,
Bill
Old May 11, 2011 | 12:54 AM
KEG64's Avatar
KEG64
#3 goes by the drivers right foot, in the corner of the foot well. #5 looks like the inner seat adjuster cover, fits on the inside seat rail.
Old May 11, 2011 | 01:02 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Window sealer strips for the door panels...
Smaller pieces are the door handle inserts used to avoid pulling the door handle strip off.
Old May 11, 2011 | 01:08 AM
GREGGPENN's Avatar
GREGGPENN
Agreed...It's used to secure the transmission tunnel carpet so it won't interfere with the go pedal.
Not sure what the inner seat adjuster cover(s) would be. They also look similar to the lock retainers for the rear hatch bins. But you're probably right.
Old May 11, 2011 | 03:31 PM
GREGGPENN's Avatar
GREGGPENN
Went thru my box of pieces today.
I was wrong guessing the longer pieces (pictured above) were window sweeps. They aren't. They are tracks for the rear compartment privacy shade. They mount inside/under the rear coupe (side) trim pieces. Right below the hatch supports, there will also be a "catch" piece to hold the shade in it's extended position.
You will find the mounting points below/back of the visible trim pieces. They mount with tapered screws.
I'm sure the smaller, box-like pieces sit in the door handles.
Old May 12, 2011 | 10:41 AM
prodjbm's Avatar
prodjbm
THANKS EVERYONE !!! greatly appricaited
To Need help identifing interior parts
