How do I pull codes on a 94?
Old Apr 20, 2002 | 11:52 AM
John Row's Avatar
John Row
Default How do I pull codes on a 94?
I bought the Computer Module Training book about a year ago just for this occasion. Now I can't find the %&#*%& thing.
Car started with a "Check Engine" light the other night. It ran OK. I ran it to the store. After parking for about 30 minutes, I had to crank it for about 10-15 seconds (normally it starts instantly), it idled like crap and stalled. I cranked again for 5-10 seconds and it started. No "Check Engine", it ran fine all the way home ( I ran it up to about 5K, no hesitation). Next day it started instantly, no "Check Engine", no problems.
I'll probably find that %&#*%& manual about 30 seconds after someone tells me the drill. :rolleyes:
TIA
Old Apr 20, 2002 | 12:24 PM
STL94LT1's Avatar
STL94LT1
Default Re: How do I pull codes on a 94? (John Row)
On the 94, with the ignition off short the 4th pin from the left and the pin directly below it, turn the ignition ON, do not start the vehicle.
This post corrected by PeteL.
[Modified by STL94LT1, 7:03 PM 4/20/2002]
Old Apr 20, 2002 | 01:42 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Default Re: How do I pull codes on a 94? (STL94LT1)
Here is quote from David-F from a couple of years ago:
You can't jump A to B on a 94 it uses a 16 pin ALDL connector you have to jump 4 to 12 which is the 4th from the left on the top row and the one just under it. Then turn the key on and watch the speedo were the speed is displayed and you will be able to read code in 1.1 CCM, 4.1 PCM(ECM), 9.1 ABS/ASR, A1 SIR..
Old Apr 20, 2002 | 02:39 PM
John Row's Avatar
John Row
Default Re: How do I pull codes on a 94? (PeteL)
Thanks, that's roughly what I remembered. Now where did I put that paper clip?
Old Apr 20, 2002 | 03:00 PM
STL94LT1's Avatar
STL94LT1
I just looked at my 94 and PeteL is right. You connect the 4th from the left pin and the one directly below it.
To How do I pull codes on a 94?
