C4 of Year Winner (appearance mods) 2019
It's easier than changing spark plugs. I can't remember for sure, but I know later years (including my '89) use a smaller Toyota starter that's easier to mount and more reliable on the road. Most will recommend the use of the smaller starter -- especially if you ever plan to install headers.
Mini starter absolutely. More $$ up front but far less trouble in the future. You should be able to do the swap on ramps. Just: insure battery is disconnected, attaching bolts for mini are correct length, all wires are replaced exactly as they were removed. Present starter is heavy, snaking out between the exhaust and transmission lines can be a challenge but doable.
Can I get this starter at NAPA?
These wires you talk about, which wires are you referring to? the ones attached to the starter?
this sounds like a neat fix, witch toyota starter did you use?
I believe the OEM starters were also made for/by Toyota. I'm not suggesting you convert to another starter originally installed in some Toyota.
When you buy a starter, just tell the parts counter your model year is 89, 90, or 91. You should get the smaller one I (we) are referring to. They are around $100 IIRC.
At first glance, the link in post #7 (above) may explain the history, but I haven't read it (yet).
Originally Posted by uptown193
Only the negative
The positive is more important. It's a large cable running straight from the starter to the battery. With the battery end connected and the starter end loose, anything metal you touch will create serious arcing.
I will make sure to disconnect everything when I do it.
