Cooling question
Old May 11, 2011 | 08:02 AM
Harley2398's Avatar
Harley2398
2nd Gear
Default Cooling question
My 96 analog guage will get to 260, the digital guage will only get to 220, which one is most reliable?
Old May 11, 2011 | 08:45 AM
TWISTERUP's Avatar
TWISTERUP
The analog gauge is non linear and by design not as accurate as your digital--trust your digital gauge
Old May 11, 2011 | 08:51 AM
Harley2398's Avatar
Harley2398
2nd Gear
Thanks, makes you a little nervous watching that gauge creep up.
Old May 11, 2011 | 08:58 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Unless it's "pegged" all the way to the needle stop, it is not reading 260.
Look real close, and I bet the needle is just shy of the shaded area on the gauge.
Old May 11, 2011 | 10:40 AM
toptechx6's Avatar
toptechx6
Here is a link to an online copy of the 96 owners manual in PDF format courtesy of forum vendor GM Parts House.
http://www.gmpartshouse.com/download...96corvette.pdf
See page 2-96 for an explanation concerning temp gauge operation.
Old May 11, 2011 | 04:52 PM
greenbay1's Avatar
greenbay1
2nd Gear
Default 94 runs hot
My 94 coupe runs hot. DIC says 225 in traffic around 210 at speed. Had the car a couple of months. Outside temp low 90s. Is this normal for this model year?
Old May 11, 2011 | 04:56 PM
hooked073's Avatar
hooked073
Normal
Old May 11, 2011 | 04:58 PM
RollaMo-LT4
225 in stop and go traffic is not at all unusual.
If your not moving, there isn't any airflow across the radiator fins unless the cooling fans are running.
And they don't come on until approx. 225-228 range (depends on year).
Running 210 at speed is not really normal, but depending on conditions it is possible.
At any speed above 40mph, there should be enough airflow across the radiator fins to keep the coolant temp in the 195-198 range.
Old May 11, 2011 | 05:00 PM
greenbay1's Avatar
greenbay1
2nd Gear
Thanks to all for the response! Going to have system flushed and cleaned to help!
To Cooling question
