85 starting problems (backfire/popping)
Old May 11, 2011 | 05:42 PM
Camocorvette79's Avatar
Camocorvette79
7th Gear
Default 85 starting problems (backfire/popping)
I have an 85 coupe that wouldn't start after I drove it home the other day. I was a little peeved so I drove my truck around for a few days. Then tried to start it and it started right up. Then a few days later I drove it for about an hour and parked it for about an hour and I went to start it and it wouldn't start again. But now while I'm cranking there's popping and backfire coming from the exhaust. I waited a while to see if there was any change but still no start, just the popping from the exhaust.
Old May 11, 2011 | 08:16 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
The first thing I would do is remove the dist cap and see if there's any moisture or carbon tracking.
Old May 11, 2011 | 10:34 PM
black85's Avatar
black85
I would pull a plug and smell to see if raw fuel is on it.
If wet, than no spark. If not, probably no fuel.
Check for spark with an assistant watching the plug near a ground (like the head). Don't have them hold it, but try to set it somewhere where it will lay next to the metal and have them watch it. It should be a nice big blue spark not a wimpy little orange one.
Listen for the fuel pump to prime if you have spark and no fuel. I don't think this will be the case b/c you have that popping. This is the humming noise you hear for 5 sec or so with key turned to on without engaging the starter.
If you have spark and fuel, check the timing. This is very easy to do. If you own a timing light, you probably know how to do this. If not, get a buddy to do it.
Good luck. Let us know how you do. I could list off a few more basic things to check.
Dave
Old May 11, 2011 | 10:36 PM
Muffin's Avatar
Muffin
Originally Posted by Paul Ruggeri
The first thing I would do is remove the dist cap and see if there's any moiture or carbon tracking.
Then wires.
Old May 11, 2011 | 11:04 PM
black85's Avatar
black85
Yes. I forgot to mention plug wires! You can look under the hood in the dark for arcs along the spark plug wires (if you can get it started). This will show if your spark is all "leaking out." This will become undrivable, first occurring on rainy days.
Old May 11, 2011 | 11:42 PM
jfb's Avatar
jfb
Backfiring is caused by spark during intake valve open which is a spark timing issue. Check spark timing.
Old May 12, 2011 | 08:26 AM
Muffin's Avatar
Muffin
Actually this was my knee jerk reaction but his problem seems to be intermittent. If his distributor is tight and it sometimes runs how could timing be off? EST failure? ICM failure?
no mention of codes.
Old May 12, 2011 | 04:16 PM
TWISTERUP's Avatar
TWISTERUP
That's where I'd start because of the popping/backfiring.
Old May 15, 2011 | 02:15 PM
Camocorvette79
7th Gear
Well I got it fixed. turns out it was a timing issue. And once I fixed that I got new wires and plugs. Runs like a top! Thanks for all the help
Old May 17, 2011 | 12:31 AM
jfb's Avatar
jfb
Another satisfied customer!
To 85 starting problems (backfire/popping)
