Intake manifold port size?
Old May 11, 2011 | 09:58 PM
Crazy5.7's Avatar
Crazy5.7
Default Intake manifold port size?
Can anyone tell me the size of the stock intake port on an 89 L98 with stock heads? I've been searching and searching but cannot seem to find an answer. Maybe even the stock gasket port size?
Old May 11, 2011 | 11:34 PM
Crazy5.7's Avatar
Crazy5.7
I'm looking for length by width to clarify. I suppose even the specs of the intake port on the 113 heads would do as well.
Old May 11, 2011 | 11:43 PM
1989TransAm's Avatar
1989TransAm
If you do not get an answer I can have it for you tomorrow. I have access to a stock TPI intake. I assume you want the part next to the gasket as the intake port narrows by the injector.
Old May 11, 2011 | 11:50 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
I'm pretty sure they use a 1204 gasket (1.23" x 1.99") Seems like they're 163cc and flow about 185cfm at peak.
Oh yeah...40lbs lighter than iron headed predesessors
Old May 12, 2011 | 11:35 AM
1991Z07's Avatar
1991Z07
Too small...
I can't say...might find some references in the shop manuals, though.
Old May 12, 2011 | 12:45 PM
GREGGPENN's Avatar
GREGGPENN
That's funny (that you think it's funny) because AFR180's have a 1.23" x 1.99" intake port. And, they're considered direct replacement for gasket/port match. http://www.airflowresearch.com/index.php?cPath=24_25
1256/1204 are the same port size IIRC.
Old May 12, 2011 | 01:23 PM
1991Z07's Avatar
1991Z07
My STOCK heads CNC-ported just barely flow 230 CFM...comparing those AFR's to a stock head is a joke. They flow 260 CFM in street trim, and 270 CFM in Competition trim...so they are FAR from a stock flow. And just slightly bigger in size than the stock ports as well.
My stock heads on the original 43k mile motor have at least 3/16" material between the edge of the gasket and the port...my ported heads took it all the way to the gasket.
Old May 12, 2011 | 02:06 PM
1989TransAm
I measured a port on a stock TPI intake. This at the gasket surface and the ports vary somewhat.
1.155" width X 1.778" tall. The port narrows as it leaves the gasket surface. So the inside area is not near this large. I can measure inside if you want.
Edit: I could not stand my spelling anymore. very=vary
Old May 12, 2011 | 02:13 PM
GREGGPENN's Avatar
GREGGPENN
When comparing AFRs to stock, I was ONLY referring to port size. You said the dimension I posted were too small. (Oops, they're smaller.)
Originally Posted by 1989TransAm
I measured a port on a stock TPI intake. This at the gasket surface and the ports very somewhat.
I still say the 1204 (or 1256) gasket is the most commonly sized gasket for replacement. (No idea why the OP wanted the measurements).
Old May 12, 2011 | 02:18 PM
1991Z07's Avatar
1991Z07
You are taking yourself WAY too seriously...
I said the ports were too small (tongue in cheek) period. I wasn't referring to your post AT ALL. The stock ports are too small to make any reasonable power for an L98...
Old May 12, 2011 | 02:28 PM
GREGGPENN's Avatar
GREGGPENN
Interesting...it didn't come across that was at all. My apology. (Or,,,nice save. )
Reasonable power is a relative term. 350hp is the number most commonly associated with the 113 heads (e.g., their so-called-limit w/o porting).
Old May 12, 2011 | 03:08 PM
1991Z07's Avatar
1991Z07
For me...400 HP is reasonable. 405 was what the ZR1 came with, and in a C4 it was a pretty fun ride. Too bad it wallowed like a pig due to the added weight and the higher C/G.
New C6's come with 430 HP standard. If you want to play with anything newer, 400 HP is a minimum of what you need.
Just my opinion...
Old May 12, 2011 | 04:36 PM
GREGGPENN's Avatar
GREGGPENN
I won't disagree with any of that!
Old May 12, 2011 | 07:39 PM
Crazy5.7's Avatar
Crazy5.7
Thank you very much! That's exactly what I needed and I greatly appreciate it!
I'm trying to figure out if the intake manifold I have will work with my stock heads, because it has been gasket matched to a 1205.
P.S. 350hp seems pretty reasonable for an L98 on stock heads. Especially when they're rated at 245. That's like 100 shot
Old May 12, 2011 | 09:44 PM
Crazy5.7's Avatar
Crazy5.7
Does anyone think there would be an issue running an intake manifold that has been gasket matched to a 1205 on stock heads?
Old May 12, 2011 | 09:50 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
The 1205 is a good amount bigger than the factory ports on the 113 head. I am having my heads matched to the 1205 gasket because the intake I am using an intake matched to that gasket as well. I think it will work, but its not ideal.
Old May 12, 2011 | 09:55 PM
Crazy5.7's Avatar
Crazy5.7
Dang. So many options. I can either run with what i got, save up and wait for new heads, or pull mine and match them. How much difference do you think there would be by just slapping this superram on?
Old May 12, 2011 | 10:31 PM
GREGGPENN's Avatar
GREGGPENN
I remember seeing 1 or 2 reports of increases in the 40-50hp range from an intake-only swap (to a SR). I would expect that to have included a port match though!
Who knows how much it would hurt to put a 1205 intake on stock heads. My guess is you'd lose up to half the potential...meaning you wouldn't be terribly impressed with that swap alone. You'd feel it though.
Cam, port match, bowl-blend, and a SR would be worth it though!
BTW...1205 is 1.23 x 2.09"
Old May 13, 2011 | 10:02 PM
Crazy5.7's Avatar
Crazy5.7
Anyone know a good place in central texas for head work?
To Intake manifold port size?
