Check Engine Code #26-Quad Driver 4
ECM DTC 26 indicates a problem with one of the following circuits.
1) Evap canister purge solenoid
2) EGR solenoid valve
3) Air pump relay
4) Air bypass solenoid valve
The ECM monitors the voltage and current to determine if
there is a problem with any of the 4 circuits.
On the ECM Gray colored connector
Pin A1 Dark Green/Yellow wire is for the Evap canister purge solenoid
Pin A2 Gray wire is for the EGR solenoid valve
Pin A7 Brown wire for the Air pump relay
Pin A8 Black/Pink wire for the Air bypass solenoid
A GM tech would use a TECH 1 tester to turn on each solenoid or relay
and verify the ECM detects the proper voltage. The current draw for the
relay or solenoid should also not exceed .75 amps.
If either the voltage or current measurement is not correct for
20 seconds, DTC 26 is set.
The chart lists a method to test each circuit using a Digital volt meter.
You can disconnect the Gray plug at the ECM. Set the meter to read
at least 2 amps of current. One circuit at a time you place the red probe on each pin and the black probe to ground. Turn the ignition On.
Each relay/solenoid should energize. The current flow should not exceed
.75 amps.
If the GM "certified" tech mentioned advised you to replace the ECM based on the code without following the troubleshooting chart in the FSM I would avoid him in the future.
The EGR and EVAP solenoids are common failure items that can cause this code. A quick test is to check resistance across the two pins of the solenoids with an ohmmeter, a bad one will be "open" = infinite resistance.
The solenoids are located under the fuel rail covers,canister purge EVAP, on the right side shown here (red and blue connector):
EGR under left fuel rail cover shown here "blue connector":
To remove the fuel rail covers simply lift straight up.
