Knock sensor connector
Old May 14, 2011 | 09:18 PM
gtphillips72's Avatar
gtphillips72
Default Knock sensor connector
I am trying to get the knock sensors out of an LT1 to drain the coolant. The connector spins, but won't come off with a fair amount of prying force. I got the clip on the side to come loose, but that didn't seem to affect anything. I don't want to break it. Help!
Old May 14, 2011 | 09:43 PM
myk7's Avatar
myk7
If it's like any other knock sensor I've seen, you just squeeze it to unlock it and pull... I don't recall any kind of clip on the side though, could be a different deal.
Is it a big round sensor?
Old May 14, 2011 | 11:38 PM
gtphillips72
Yes, it's round needing a 23 mm wrench. What do you squeeze?
Old May 15, 2011 | 12:29 AM
Metal Brain's Avatar
Metal Brain
Cruising
The grey connector is kinda oval shaped. at the widest point squeeze just like myk7 said it'll pop right off..............
Old May 15, 2011 | 02:27 AM
gtphillips72
Thanks very much, it worked great.
Old May 15, 2011 | 07:57 AM
WW7's Avatar
WW7
Don't forget, when reinstalling the sensor it has to be torqued to a specific number or you run the risk of it not reading the engine knocks correctly...WW
To Knock sensor connector
