Failed Emmissions Test?
My car did have a 64 code which I believe is a "lean right oxygen sensor"
First is the code 64 - a lean oxygen sensor?
Second will this effect my NOx ?
The Seven possibles are:
-Inoperative/ineffective EGR system
- Excessive lean air/fuel ratio
-Maifunctioning cats
-Excessive spark advance
-Faulty Thermostatic Air Cleaner system
-Engine deposits or mechanical defect
-Faulty cooling system
Any help would be appreciated!
Chris
if the solenoid supplies a vac signal at the right time, try to activate the valve with the car running to see if you can affect the idle. You can test it off the car too, a good one will open, even without exh backpressure if you pump it up quickly.
high compression, too much spark advance will also elevate the NOx. A big vacuum leak will make the car lean- that will elevate the reading too.
