Clutch problems with your stroker 6-speed?
Old May 15, 2011 | 09:35 PM
94LT1Z07's Avatar
94LT1Z07
Default Clutch problems with your stroker 6-speed?
anyone experience vibration after replacing the Dual Mass Fly Wheel. Suggestions for a replacement. My Fidanza sounds like a very loud box of rocks.
Old May 15, 2011 | 09:49 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
That's a common complaint after converting from a DMF to SMF. Did you change to a sprung-hub clutch? If so, a SPEC FW is considered the best SMF alternative at this point (because of it's heavier weight).
Or, seek out a used DMF unit. Lower mileage and/or newest specimens are probably your best bet.
Old May 16, 2011 | 12:27 AM
96GS#007's Avatar
96GS#007
If your engine was built to use the Dual Mass flywheel, did you install the balancing weights on the Fidanza prior to install? If you didn't, you have an engine built to accept a flywheel with an offset weight cast into it that is running a neutrally balanced Fidanza.
...and yes, if you use a single mass flywheel (even with the sprung hub), you get lots of noise at idle with the clutch engaged/tranny in neutral, as well as while accelerating thru the first few gears.
Old May 16, 2011 | 09:25 AM
94LT1Z07's Avatar
94LT1Z07
Thanks, I sold my low mileage DMF (cheap) on the advice of my builder. Said it would not handle the high torque of the 383. Can ZF Doc provide an economical remedy the solution, without rebuilding the transmission? Curious.
Old May 16, 2011 | 09:32 AM
94LT1Z07's Avatar
94LT1Z07
The engine was built incorporating an internally balanced forged rotating assembly. So, to answer the question, no we did not add weights to the fidanza (may be a problem).
What clutch and flywheel combinations do you guys run. To your knowledge, which produce the greatest success rate?
Guys, thank you very much for your help. I appreciate it!
Old May 16, 2011 | 10:20 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
My installer told me a story about someone that put a lighter weight flywheel and it made a horrendus noise and vibration with clutch out and in neutral.
Mine with a heavier flywheel does not make near as much noise, still a "rocks in the can" rattle with the clutch in and in neutral.
I get a lot of vibration at 4k RPM, think I've narrowed it down to a bad engine mount. going to try solid mounts next if I can find them.
Old May 16, 2011 | 10:59 AM
Dr.Huxtable's Avatar
Dr.Huxtable
my car does the same thing also. Had a SMF in there with the black tag and it sounded just like your describing. I freaked at first thought i had bought a lemon car but soon found out after reading on zfdocs site that this was normal. THe new setup i have will be very similar hto yours. Fully forged 396, new SMF and a sprung hub spec 3+ clutch. We'll see how that sounds
Old May 16, 2011 | 11:11 AM
96GS#007's Avatar
96GS#007
If it was built to be internally balanced, then the weight should not be added to the flywheel.
With a single mass flywheel (SMF), some vibration/noise is normal. Based on your first post, I'd say that there's not an issue. If you used a clutch disc with a solid hub (vs a hub with springs), it'll be even worse. Moving to a sprung hub will help a little. Moving to a heavier flywheel will help a little more. To get rid of it completely, you need to go back to the dual mass flywheel setup.
FWIW, I use a SPEC steel SMF setup with my 383. Definitely a "box of rocks" at idle
Old May 23, 2011 | 05:18 PM
94LT1Z07's Avatar
94LT1Z07
I've found out that my builder used chinese parts (t/o bearing and pressure plate). Not his fault, I'm told that the OEM replacement parts are very hard to find for the LTX. Parts that are readily available from the regular parts suppliers (including GM) are the chinese duplicates. I found a source that has some of the good stuff. PM me for information.
The clutch kit includes: Valeo LT4 racing pressure plate, Carolina Clutch Stage 2 sprung friction disc, INA clutch release bearing, Valeo clutch release bearing retainer, GM Performance fluted pilot bearing, and clutch installation tool.
Old May 23, 2011 | 07:38 PM
5abivt's Avatar
5abivt
I built a solid roller 388 and used an aluminum flywheel with a McLeod street twin. It was loud, but the exhaust was loud too and so was the solid roller valvetrain. I had to run a high idle (900-1100) anyways so it was bearable. A few times I heard it at a rough 700 idle and I just laughed.
Did I have vibrations? Yeah just a little at about 4k that i could feel through the shifter but it stopped after my ac compressor exploded the first time I tookit to 8000 rpm. My new build uses an even lighter aluminum flywheel that has been drilled as well. I also have the new ac delete pulley lol
Old May 24, 2011 | 11:57 AM
Red Rocket's Avatar
Red Rocket
Have the GM Camaro LT1 SMF (Cast Steel/Shave .020) with the Spec 3+ clutch in my 94 396. The flywheel is 21 LBS which is similar to the Spec steel SMF which is forged. If you have the whole set up balanced and installed by a reputable shop, set you idle at 950RPM's, it sounds like the factory DMF and will last.
Went thru numerous other clutches before this set up.
Old May 24, 2011 | 12:27 PM
cv67's Avatar
cv67
St. Jude Donor '05
The DMF can handle some pretty decent power why he told you to go put a light aluminum flywheel in for the street is beyond me.
Old May 24, 2011 | 08:57 PM
5abivt's Avatar
5abivt
I agree with cruisin. For me I had tried to build a light weight motor capable of revving so it didn't make sense to keep a 44 lb flywheel bolted to the crank vs an 11 lb one. If I built a stroker for torque without trying to be lightweight the dual mass would have stayed for sure.
One of my favourite motors of all time. Check out the flywheel on this thing . Driving this car with this motor was my inspiration for building a high rpm revver !! I will hate torquey motors forever!!
Old May 25, 2011 | 07:34 AM
LD85's Avatar
LD85
I recall that mine made noise until 2300rpm, then was gone, it was mostly loud at idle in neutral, but with my foot on the clutch is wasn't terrible, just annoying...
After getting tired of exorbitant clutch and flywheel prices, I bought the TKO 600,, the TKO 600 would be perfect if it had a 6th gear, but I only used 6th gear at 80+mph, which I hardly would ever do,
so for me it was a good move, I got an equivalent or stronger tranny, top quality clutch components for the same or less than the cost of a ZF flywheel and it uses all of my stock 1985 parts, TOB, hydraulics etc.
best of all, no rocks-n-a-box sound
Old May 25, 2011 | 12:45 PM
dizwiz24's Avatar
dizwiz24
Spec stage 3+ sprung hub, lightweight fidanza aluminum flywheel, blue tag zf in my 93.
No issues with objectionable noise/vibration. There is a slight amt if you aren't driving correctly (ie. Lugging it in too high of a gear up a hill), but none otherwise.
Is it possible blue tag vs. Black tag makes a diff?
Not sure why everyone thinks heavy mass flywheels are best. Hotrod showed once that all startng line gains from a heavy flywheel are negated and exceeded by a lightweight flywheel by the end of the race. Net winner is the lightweight flywheel
Old May 25, 2011 | 05:05 PM
Red Rocket's Avatar
Red Rocket
Stuck at low 12's with my 350. Put in the SMF and finally made the 11's.
To Clutch problems with your stroker 6-speed?
