I have a 1994 LT1 I blew the engine due to the radiator hose busting on my was to work. I just bought a 383 stroker, I need to know if any of my parts will fit off my LT1 to the new engine. Its a 350 block out of an 1981 Camaro I believe. If anyone can help me please help. LOL!
Basically none. You have a LOT of work and $$$ ahead of you if you want to make an '81 Gen 1, two-piece rear seal engine work.
Your best bet is to sell it and go find an LT1 or simply have your existing engine rebuilt.
Thanks I was told it wasnt gonna be that bad but now looking at it I am gonna have to figure something else out. I just thought a 383 stroker would be pretty awesome in my vette. I didnt think it would cost that much money to get it in. Thanks again.
sell it, and use that money to rebuild the lt1. you can always stroke the lt1 into a 383 for pretty cheap. this will equal ALOT less headaches when it comes time to put the motor back in and get everything working
It sounds like the 383 is used. If so, by the time you would have the rotating assembly checked / re-balanced, buy the adapater, and buy a new flexplate or flywheel, you'll have saved virtually no money.
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
