Your rear wheel bearing fails?? Mine knocks when i initially hit the gas and I'm runnning low on funds and want to wait until next weekend to fix it.. If the bearing ultimatly blows what happens?
Be careful, when I replaced my rear bearings, they were already broke in half. The castle nut kept the wheel from falling off.
If you know the bearing is bad, don't drive it.
...But I just got done installing Bilsteins...In the LR wheelwell, the plastic wheelwell liner was shattered in 3 pieces; the upper shock mount had been torn out of the frame (and boogerly welded back in); the ASR housing had a large hole rubbed through it (and patched); and it has a new castellated nut & cotter pin on the axle shaft...
...All from previous owner...
...But offhand, I have no idea what a failed bearing would do...And don't want to find out... :nonod:
