Little Help Please
Old May 17, 2011 | 10:05 PM
gsff19's Avatar
gsff19
Cruising
Default Little Help Please
Here I go, Im changing my 84 Cross-Fire to Carb. I am trying to see if anyone can help me out with a step by step do and dont list?
Parts are on the way and I need a little direction so I don't screw up.
Please and thank you.
Greg
Old May 18, 2011 | 06:43 PM
gsff19's Avatar
gsff19
Cruising
Anyone..... Anyone......
Old May 19, 2011 | 10:12 AM
HlhnEast's Avatar
HlhnEast
You might search forum member ex-xfire's posts and see whats there. Its been done, do an advanced search of the C4 Tech/Performance.
Old May 19, 2011 | 05:27 PM
BillGBuf's Avatar
BillGBuf
Default WTB Rubber seals on air cleaner base Ex Con
Hi,
If the two big rubber seals that fit onto the ends of the black air cleaner base are in excellent condition I'd like to buy them if they are for sale. Thanks
Bill
Old May 20, 2011 | 12:05 PM
bwiencek's Avatar
bwiencek
it's a pretty simple bolt-on affair - the only "gotcha's" are going to be the overall height of the intake/carb/air cleaner that you chose and if it will fit under the stock hood. Just take your time, clean up stuff as you go and before removing the intake (as to not drop dirt/grit/gunk down the engine.) Use a rag to line the lifter valley after removing intake and before cleaning up the intake gasket surfaces - vacuum everything up before re-assembly.
I'd add that it's a great time to do a cam swap - since you've got a flat tappet cam and are going to a carb you can use a cheap $120-150 cam/lifter set and get a lot more performance out of the engine at the same time since you don't have to worry about computer compatibility and are going to a shorter runner...
To Little Help Please
