Auto Trans Fluid Flush Report
Old May 19, 2011 | 04:46 PM
tlong's Avatar
tlong
Default Auto Trans Fluid Flush Report
Did the cooler line removal method this afternoon and put a dozen quarts of Castrol Dexron VI into the tube. All went well with a little spill out of the plastic tubing. The old stuff was pretty gray after 50K and 8 years. Now nice and rosey. It closely resembled a blood transfusion.
The previous running temperature of the transmission was about 210-220. After a good 30 minute test cruise the digital readout reported a steady 196. That's a welcome change. It's probably subconscious but I think it shifts smoother, like right after I Zaino it. The fluid was $100 but that's cheap maintenance in your own garage I guess.
I will report back if it ruins my transmission in a thousand miles.
Old May 19, 2011 | 05:02 PM
gtphillips72's Avatar
gtphillips72
Would you go into more detail about the procedure?
Old May 19, 2011 | 06:10 PM
tlong's Avatar
tlong
Unscrew the top tranny cooler line (not metric!) going into the radiator and put a clear plastic tubing on it, clamp it and stick it in a bucket. Crank the car and watch it pump out until it sputters. Put in 4 quarts, repeat twice more. The capacity is about 11 quarts. Put it in gear for a few minutes and top off to the top of the 190* hot line.
This is straight from the Man Gordon Killebrew. I didn't clamp the tubing on the line and had spillage.
Over-filling will be a major mistake. Add the last few slowly. Test drive and check level hot running.
Old May 19, 2011 | 07:44 PM
thearborbarber's Avatar
thearborbarber
I flushed my tranny yesterday and I noticed a 10 degree top in tempurate. It went from 203 to 193 degrees.
Old May 20, 2011 | 01:18 AM
gtphillips72
Thanks, that was very helpful.
Old May 20, 2011 | 08:53 AM
tlong's Avatar
tlong
Hi Pete,
Care to pay off on your tease? If Killebrew and I did something wrong help us out. I know your expertise level and am not trying to be a smarty pants. I just prefer to do things myself.
www.youtube.com/watch?v=4oxpXHrOR8I
Old May 20, 2011 | 10:44 AM
rickneworleansla's Avatar
rickneworleansla
Originally Posted by Pete K
If Gordon advised to run the engine until the fluid sputtered, you ran the oiling system dry. The internals of an auto trans are very durable when the fluid is flowing, but can be as delicate as an eggshell without lube.
To do a fluid exchange is one thing, but to pump out, replace, and repeat makes me cringe. If you were here, I could pull out trashed pumps to illustrate the damage that could occur.
The thoughts of the hardened pump vanes grinding away on the soft aluminum pump housing makes me think Gordon should modify his recommendation.
*That is a politically correct way to say he should yank that video off you tube.
If I were doing a home fluid swap, I would unhook both lines. Using 2 new, clean, 5 gallon buckets, I would fill one with 12 quarts of fluid, start engine, and exchange the fluid.
***Not let it run dry.
Then, I would drop the pan, replace the filter, and add fluid to the pan.
Sounds like a better way to me. How often do you change your fluid and filter? I was told once a year is good for a street/occasional track Vette.
Now where's the video?
To Auto Trans Fluid Flush Report
