what valve springs ?
Old May 21, 2011 | 05:55 AM
Mohammed_z's Avatar
Mohammed_z
Default what valve springs ?
cam installed by previous owner in my '94
I don't know the cam specs and the car needs new valve springs...
what valve springs should I go with ?
someone told me if I don't know the lift of the cam it's a big problem !! I may choose the wrong springs !
Old May 21, 2011 | 08:53 AM
oldalaskaman's Avatar
oldalaskaman
cams arent that spendy, as long as you're doin the top end, change cams, that way you'll know, there's several ways to measure lift and duration with out removing it , but by the time you've done that you could have the new one in. i'm wondering why you think you need springs and how you came about that with out knowing how to measure a cam?
Old May 21, 2011 | 12:47 PM
Mohammed_z's Avatar
Mohammed_z
the guy didn't install new springs with the cam , car loses some power at high rpm , i guess they call it "engine bogging" .
Old May 21, 2011 | 01:33 PM
cv67's Avatar
cv67
St. Jude Donor '05
Its called valve float and not good for anything.
Sounds like he either doesnt have the right springs in there or they arent setup right.
Measure what you have first then proceed.
Old May 21, 2011 | 01:55 PM
96GS#007's Avatar
96GS#007
Best bet is to determine the cam lift. If that's not possible...
Given that it's a street car I would be surprised if the cam is over .625 lift. With that as an assumption then I would look at CompCams Beehive™ Valve Springs.
Specifically I'd go with part number 26918-16. You'll also need new locks and retainers. This should be overkill (relative to how much lift these springs support) for whatever cam the engine has. Seat and open pressures are typical of springs in a street engine. Of course you do so at you own risk since you don't have the cam specs.
Linky
Old May 21, 2011 | 04:23 PM
Mohammed_z's Avatar
Mohammed_z
ok I need a digital caliber , I googled how to measure but got little confused. what's the correct way ?
measure long and short distance (idk from where) , subtract and then multiply by rocker arm ratio ?
Linky
thanks for the help, But I wont take the risk, I'll measure the cam lift.
To what valve springs ?
