Need tranny help quick!
Old Apr 21, 2002 | 03:35 PM
cprgmr's Avatar
cprgmr
Default Need tranny help quick!
Guys - I'm only a few steps away from removing the tranny and I think I've reached one of those sticking points. The service manual says to remove the TV cable at the transmission. I did release tension on the cable at the engine (ASR box), but the cable that goes into the tranny is of course attached to something in there. Any ideas on how to remove the TV cable at the tranny? Thanks in advance! :)
Old Apr 21, 2002 | 08:02 PM
vette_tweak's Avatar
vette_tweak
Default Re: Need tranny help quick! (cprgmr)
The trans end of your TV cable has an eyelet on the end of it. This attaches to what I can best describe as a rod shaped like a "?" (question mark) or hook on the end of it in the trans. It's not actually round, something like a "C" section on a rod . Anyhow, remove the bolt holding the TV cable to the trans. Pull the cable up until you see the "?" part of the rod. Simply unhook the cable from the rod. :cheers:
Old Apr 21, 2002 | 08:10 PM
cprgmr's Avatar
cprgmr
Default Re: Need tranny help quick! (vette_tweak)
Thanks for the info! I knew there was some way to do it! :) Just out of curiosity, isn't there some tension on the eyelet? How would you get the hook back out of the trans to reinstall it to the TV cable when putting the tranny back in? Thanks! :)
To Need tranny help quick!
