Antenna
Old May 22, 2011 | 07:46 PM
Tad's Avatar
Tad
Cruising
Default Antenna
My 1992 electric radio antenna is shot. Anyone replace their's with a fixed antenna? Any problem with the Bose Stereo interface? I'd like to save the 200 bucks for the replacement and just put on a old fasion fixed antenna. Let me know what you did to make one work.
Old May 22, 2011 | 07:58 PM
thearborbarber's Avatar
thearborbarber
subscribing
Old May 22, 2011 | 08:38 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
Mine froze this past winter. I bought a replacement from another CF Member. It will get installed ASAP.
Old May 22, 2011 | 08:58 PM
l98tpi's Avatar
l98tpi
Max G’s
I replaced my power antenna with stationary. No problems with reception or anything. I just removed the pwer antenna from the car, but left the lead that plugs into the antenna and connects to the back of the radio. You will have to find a female to female antenna plug to connect the lead from the rear of the radio to the new stationary antenna. Just mount a stationary antenna in to existing hole that the original antenna ran through. I just used a stationary shorty antenna. It may be difficult to find the female to female antenna connector so here is the manufacturer and part number- Antenna Works/ pn 40-UV41.
Old May 22, 2011 | 10:47 PM
thearborbarber
What stationary antenna did you use?
To Antenna
