power steering pump-relief
Old May 23, 2011 | 10:31 AM
choopes's Avatar
choopes
Default power steering pump-relief
I finally had to seek outside help to get my ps pump mounted on my 93 coupe. It seems the return hose was in the wrong position and had to be put in a vise and bent to line up with the rigid hose going over to the resivor. (thank you advance auto parts)They showed me a trick I want to share. After everything is hooked up, but the belt is not yet installed. Top up the resivor, the spin it by hand. Spin it in both directions. Wait a few hours, if you can and repeat. With mine I could actually feel added tension when the air worked out, and it was primed. This is so simple that I had overlooked it. It's easier the racking the steering, or opening the line to get the air out. If I had it to do again, I would use turn one for repair, or simply bought a A/C delco pump.
