Additive to pass emissions.....
Old Apr 21, 2002 | 08:20 PM
OrangeC4's Avatar
OrangeC4
Default Additive to pass emissions.....
I remember reading somewhere here that adding some kind of alcohol to your fuel will make your emissions burn cleaner. Does anybody know what I am trying to remember? I think it is isoproponyl(I don't think I spelled it right).
Old Apr 21, 2002 | 08:28 PM
pablocruise's Avatar
pablocruise
Default Re: Additive to pass emissions..... (OrangeC4)
I've seen it here too. Why? Did your Vette not pass?
I also thought I heard that Alcohol is harsh on catalytic :confused: :confused:
Old Apr 21, 2002 | 08:32 PM
OrangeC4's Avatar
OrangeC4
Default Re: Additive to pass emissions..... (89 Paul in Cal)
I passed emissions with flying colors. It is my friend that is having trouble with his Civic, his noxins were too high.
Old Apr 21, 2002 | 08:38 PM
TIMSPEED's Avatar
TIMSPEED
It's Ethanol(spelled correctly?) if I remember right. Put like one SPOONFUL in your gastank and voila. I'll ask my friends though to make sure.
Old Apr 21, 2002 | 08:43 PM
OrangeC4's Avatar
OrangeC4
Default Re: Additive to pass emissions..... (TIMSPEED)
Thanks TIMSPEED. That is it, I remember the name now that I read it again. :cheers:
Old Apr 21, 2002 | 08:45 PM
FU's Avatar
FU
Race Director<br><img src="/forums/images/ranks/7k-10k.gif" border="0">
From: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06 thru '20
A couple of bottle's of drygas will do the trick.
Old Apr 21, 2002 | 09:15 PM
STL94LT1's Avatar
STL94LT1
Add a gallon of ethanol, it will heat up the cats to burn off the excess emmissions.
[Modified by STL94LT1, 1:23 AM 4/22/2002]
Old Apr 22, 2002 | 12:37 PM
85 Dave's Avatar
85 Dave
Default Re: Additive to pass emissions..... (STL94LT1)
You had it right before, isoproponal (isopropryl) is best. If there is any water in the gas tank, methanol and ethanol will mix with the water, but not the gas. Isoproponal will mix with both water and gas. Don't use rubbing alcohol from the drug store. It has 30% water in it. Use DryGas. Check the label, because some DryGas uses methanol. Add up to 10% by volume. Also have your friend do 10 WOT passes from 0-70 mph just before the test. This will burn off any sulfur on the cat converter.
To Additive to pass emissions.....
